Engine Rebuild question...
Old Aug 28, 2006 | 12:52 AM
das2123's Avatar
das2123
Default RE: Engine Rebuild question...
You could put a SOHC magnum engine in there also
Old Aug 28, 2006 | 02:14 AM
NEONRT98's Avatar
NEONRT98
How much modding would it take to put a SOHC Magnum in there? What are the advantages/gains?
Old Aug 28, 2006 | 02:26 AM
das2123's Avatar
das2123
Besides the engine, you would need a 1st gen crank pulley, a 2nd gen starter, homemade CAI, relocate the battery and a few other things. The magnum engine replaced the DOHC engine and is rated at 150HP, but is a SOHC. There would be no benefit if you already have a DOHC engine.
Old Aug 28, 2006 | 12:16 PM
neoncrazy101's Avatar
neoncrazy101
ORIGINAL: spudsterier
if you really wanted to go the original route....you could always put a dohc in there and then hold onto the sohc.....neons arent like muscle cars....if its not original, it doesnt matter......besides if you rebuild the motor with aftermarket parts, your gonna be just as far away from original as putting in a dohc.....besides a dohc is alot of fun
yea the more and more you guys were saying and the more and more i got to thinking. that i should just do that...put the DOHC till it blows or something and put in the SOHC... and to das... never thought about the SOHC Magnumn... hmmm...
