Tachometer Install Problem...
Old Sep 16, 2006 | 01:27 AM
  #21
das2123's Avatar
das2123
Default RE: Tachometer Install Problem...
^^^Under the dash as in behind the cluster?
Old Sep 16, 2006 | 02:08 AM
  #22
spudsterier's Avatar
spudsterier
behind the cluster is the easiest way...then you dont have wires ran through the whole car.....behind the cluster works the best if you have a stock tach.....since you have to disconnect it anyways
Old Sep 17, 2006 | 01:11 PM
  #23
xdeathwishx's Avatar
xdeathwishx
yes behind the cluster.
