head gasket
Old Aug 29, 2006 | 09:48 PM
95neonriceeater's Avatar
95neonriceeater
Default head gasket
well my head gasket is really messed up
we're changing it this weekend
and i'm also putting in my TB and hopefully custom CAI
do you think that the hg being messed up is hurting my horse power?
and when i change my hg is there anything else i will need to change?
thanks in advance
Old Aug 29, 2006 | 11:57 PM
spudsterier's Avatar
spudsterier
Default RE: head gasket
if your hg is messed up good enough then you would have lower compression....which would make it a little less peppy
get a whole head gasket set and change all the gaskets you remove.....
depending on the year you might wanna change the timing belt and tensioner pulley while your at it.....unless you enjoy ripping your motor apart every once and a while
Old Aug 30, 2006 | 12:38 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Who doesn't???
Seriously though, if you have close to 100,000 miles on your belt, pump, and tensioner pulley it would be a great time to change those as well.
Old Aug 30, 2006 | 01:08 AM
spudsterier
ive got 139,000 on mine and dont plan on changing it any time soon...unless it goes out that is
Old Aug 30, 2006 | 01:10 AM
das2123's Avatar
das2123
Why not???
Looking for an excuse to swap motors????
Old Aug 30, 2006 | 01:16 AM
spudsterier
maybe....i dont have any problems with it as of yet.....and i plan on putting the soon-to-be bored motor in there within a month or two.....ive got 3 tensioner pulleys, 2 new headgaskets, 4 timing belts 2 water pumps, and about half a dozen tensioner pins sittin in crates in the garage........i just dont feel like doin the work...and i hate doin timing.....i would rather rip out a motor and install a new one..or change a tranny out before i wanna mess with the timing
