Power Lock Question
Old Sep 2, 2006 | 03:21 AM
Buzz's Avatar
Buzz
Default Power Lock Question
I have a 98 Neon that the power locks do not work neither switch will unlock or lock.I cant find anything about a bcm for this model.Is there a relay or something else to check.......thanks
Old Sep 2, 2006 | 03:58 AM
racerx55's Avatar
racerx55
Default RE: Power Lock Question
have you checked fuses in the box on the left side of the dash?
Old Sep 2, 2006 | 04:02 AM
Buzz's Avatar
Buzz
I forgot to mention that in my post but yes I did check the fuse and it was ok.
Old Sep 2, 2006 | 11:55 PM
hndawht's Avatar
hndawht
was the power locks ever working? could one of the switches be dissconnected,if not check for power at the harness switch could be bad? but i dont think it would affect both doors, or the harness in the door jam disconnected? thats where i would start good luck and let us know what u find out
Old Sep 3, 2006 | 12:31 AM
spudsterier's Avatar
spudsterier
if one switch is bad....neither will work
Old Sep 3, 2006 | 01:48 AM
ewetho's Avatar
ewetho
Also possibly an acutator
Old Sep 3, 2006 | 02:54 AM
Buzz's Avatar
Buzz
Thank you guys for all the replys..I got the wiring diagram and will start checking the switches and wires..
Old Sep 5, 2006 | 10:58 PM
Buzz's Avatar
Buzz
Both switches test good and both are getting power..Does anyone here have one with power locks that could lock/unlock and tell me where the clicking of the relay is coming from so I can test it.
