throttle body Q
Old Sep 4, 2006 | 05:32 AM
racerx55's Avatar
racerx55
Default throttle body Q
anyone know if a 95 SOHC TB (ATX) is the same bore size as a 96 DOHC ATX throttle body?
or are they different
[IMG]local://upfiles/37714/C344E2FF97144F7AABA7EC56B8589C05.jpg[/IMG]
Old Sep 5, 2006 | 12:24 AM
das2123's Avatar
das2123
Default RE: throttle body Q
ATX is 52mm and MTX is 49mm on all 1st gen neons.
Old Sep 5, 2006 | 12:44 PM
JamesonC's Avatar
JamesonC
so would it be possible to take the throttle body off an ATX and put it in an MTX? Would that even do anything?
Old Sep 5, 2006 | 12:49 PM
das2123's Avatar
das2123
ORIGINAL: JamesonC
Yes you can and yes it will. It helps throttle response quite a bit.
Old Sep 5, 2006 | 12:50 PM
racerx55's Avatar
racerx55
already did that, its helps using the bigger ATX throttle body, i was just wondering if it was different from SOHC to DOHC besides the IAC & TPS needs to be changed to fit, theyre all interchangeable other than IAC & tps plug angle
Old Sep 5, 2006 | 12:56 PM
neoncrazy101's Avatar
neoncrazy101
how hard is it to change the TB throttle cable linkage thingy? lol cause i'm gonna swap my sisters ATX TB and put it in my car and put my MTX TB on her car... but mine has cruise control so it has 2 cables instead of the 1... so how do i change the ATX one to a 2 cable set up?
Old Sep 7, 2006 | 04:41 AM
racerx55's Avatar
racerx55
just change the bracket on the side then use the shaft from the other TB with 2 on the plastic deal, take the throttle plate out with the 2 screws, then take off the TPS and theres a snap ring under there to take off the end of the shaft, if you break it oh well - the plate will keep the shaft in place, if your putting the ATX on a MTX car use the MTX spring or its way too soft
[IMG]local://upfiles/37714/FF1FE29E5A0F427D97C44CC0B352D1BB.jpg[/IMG]
[IMG]local://upfiles/37714/C136C8FAEC9F479AAE296485296380EE.jpg[/IMG]
Old Sep 7, 2006 | 09:44 AM
spudsterier's Avatar
spudsterier
i like having the auto throttle spring on my manual
Old Sep 8, 2006 | 05:14 AM
racerx55's Avatar
racerx55
i did that in the race car & couldnt control the throttle, it was too easy to push, but i also have to try to roll on the throttle easy around the corner on a really rough track & thats hard to do to begin with
Old Sep 13, 2006 | 08:05 PM
neon48's Avatar
neon48
Hey racerx55, Whats up?
Hey what all can you tell me about what size track that you run, how your car is set up & etc.
What all kind of mods do you have?
I have a 95 DOHC 5 Speed. Just had the Head shaved .010 Because blew head gasket. Put in a Centerforce clutch & Fidanaza Alum Flywheel. Got the Mopar ecm. Mine will outrun any car at our track until it hits the rev limiter at about 7500rpm. Do you run a rev limiter? If you want to chat in private my email is kcobra@direcpc.com Thanks Bryan
