No brake lights, No turn signal in rear
Old Sep 17, 2006 | 05:58 PM
HoosierBaby's Avatar
HoosierBaby
Default No brake lights, No turn signal in rear
Hi,
I'm new to the board, and need some help. My 95 neon has no brake lights and no turn signal in the rear. The turn signal indicater dash light flashes really fast on the left. The bulbs are good, the fuses are good and the brake pedal switch tests ok.......????? Any ideas???
Thanx HoosierBaby
Old Sep 17, 2006 | 07:37 PM
das2123's Avatar
das2123
Default RE: No brake lights, No turn signal in rear
Did you replace the bulbs? If so, then you may have to have a look at the wiring.
Old Sep 17, 2006 | 08:31 PM
HoosierBaby
We didnt find anything wrong with the bulbs but did replace the left one anyway
Old Sep 17, 2006 | 11:23 PM
racerx55's Avatar
racerx55
pull up the carpet in the trunk and look around for a ground wire bolted down on the drivers side, i assume youve checked fuses already?
Old Sep 17, 2006 | 11:26 PM
HoosierBaby
yes fuses have been checked and are ok. I went out a little while ago and magically I now have right brake lights and right rear turnsignal. No power is getting to the left rear socket.
Old Sep 17, 2006 | 11:48 PM
ZiggyNeon's Avatar
ZiggyNeon
another thing to you might want to try : put your turn signal on, then wiggle the hazards switch, alot of the times that unit needs to be replaced so if your turn signals stop working while you wiggle the hazards switch thats more than likely your problem. the hazards and turn signal switch is the same unit. on my car its kinda the same problem i need to switch it out cuz they dont always work, then i wiggle the hazards an bam there back on try that and lemme know if it helped
Old Sep 18, 2006 | 12:15 AM
HoosierBaby
Would that also affect the brake light????
Old Sep 18, 2006 | 12:32 AM
ZiggyNeon's Avatar
ZiggyNeon
it affected mine before screwing with that unit my buddy would tell me my brake lights on one side were out then id go check and they would be on so try that and let us know
Old Sep 18, 2006 | 12:38 AM
HoosierBaby
Nothing....I still just have a left front turn signal flashing a million times a minute....no left rear turnsignal or brake
Old Sep 18, 2006 | 01:31 PM
ZiggyNeon's Avatar
ZiggyNeon
did u check the driver side ground liker racer suggested?
