Air Bag Light?
Old Sep 25, 2006 | 06:23 PM
95_dohc_mtx's Avatar
95_dohc_mtx
Default Air Bag Light?
My air bag light came on out of absolutely no where??? it just stays on....strange...anyone know what causes that???!!
Old Sep 25, 2006 | 07:23 PM
spudsterier's Avatar
spudsterier
Default RE: Air Bag Light?
blown fuse??? or maybe a faulty unit sumwhere
Old Sep 25, 2006 | 08:41 PM
das2123's Avatar
das2123
Only way to turn it off is by going to the the dealer that I know of.
Old Sep 25, 2006 | 09:41 PM
spudsterier
unless the fuse is blown...then once you replace the fuse it goes off
Old Sep 26, 2006 | 04:15 AM
pimpberetta's Avatar
pimpberetta
If you pull the airbag from the steering wheel there should be two wires coming from behind it back in the steering column.
On my car one of the wires got severed right at the column, like what the f uck.
Maybe you got the same dealio.
Old Sep 26, 2006 | 11:39 AM
das2123's Avatar
das2123
ORIGINAL: pimpberetta
Those would be the clockspring wires for the horn and cruise control.
Old Sep 26, 2006 | 04:52 PM
pimpberetta
The wires are coming out of the airbag unit.
Yes there are red wires for the horn, but I believe the wires were black, or dark in colour from the airbag.
Old Sep 26, 2006 | 05:56 PM
das2123's Avatar
das2123
There is one connection that goes into the back of the airbag unit for the airbag and then horn. The other wires will plug into the cruise contols.
Old Sep 26, 2006 | 06:09 PM
xdeathwishx's Avatar
xdeathwishx
my airbag light goes on and off randomly. its pretty wierd.
Old Sep 26, 2006 | 07:31 PM
spudsterier
here is a question.....when the airbag light is on, do you have heat and turnsignals????
just for giggles, try starting your car, then turn the key back just a little....dont turn it off, but turn it back just a little until the key stops.....same to you xdeathwishx....maybe it gets bumped back a little when your is off, but when the light is on, the key might not be back all the way....just try it out, its worth a shot
