short shifter
Old Oct 5, 2006 | 11:55 AM
das2123's Avatar
das2123
Default RE: short shifter
ORIGINAL: spudsterier
if you remove your center console and your buddies and move your shifters side to side, the sts will have a shorter distance traveled
Which means you will get into the next gear quicker than your opponent, hopefully.
Old Nov 17, 2006 | 02:49 AM
streetbikr600's Avatar
streetbikr600
do you really have to remove the air bag senor and emergency brake?
Old Nov 17, 2006 | 05:54 AM
95neonriceeater's Avatar
95neonriceeater
all you have to do is disconnect the neg side of the battery
Old Nov 17, 2006 | 10:03 AM
spudsterier's Avatar
spudsterier
you dont have to remove any of that....just take out the center console.....remove the 3 little nuts ontop of the shifter base.....remove the horseshoe clip on the front right side of the shifter base....pull out the rod and assembly that is held in by the clip.....pull the bushing in the cable end off of the bottom right of the shift handle....then pull it out
Old Nov 17, 2006 | 04:38 PM
streetbikr600
it should only take about 1/2 and hour ...correct
Old Nov 17, 2006 | 07:32 PM
spudsterier
1/2 hour sounds good
Old Nov 18, 2006 | 01:38 AM
95neonriceeater
depending which short shifter you get make sure nothing is scrapping like it's said above
i think when i get my car finished i'm going to try to fix it
i had a question...
when i put mine on
the bottom connection for the bushing was facing hte opposite way so the shifter bushing/cable was being pulled more towards the side
is there a way to fix that or anything?
is that probably why it was hard for me to put it in reverse?
Old Nov 18, 2006 | 02:27 PM
spudsterier
i had to flip my cable end around when i put my shifter one
Old Nov 18, 2006 | 08:21 PM
95neonriceeater
thats what i did!
was it hard for you to put it in 5th/reverse?
Old Nov 18, 2006 | 10:49 PM
spudsterier
reverse was for a little while, but i got it worn in pretty good
