short shifter
Old Oct 4, 2006 | 04:47 PM
95neonriceeater's Avatar
95neonriceeater
Default short shifter
alright
so i had to take my short shifter out becuase everyone was saying how hard it was to shift into reverse
so im stuck with the stock shifter for now
and i noticed when i put it in that the bottom part that connects to the bushing is facing the opposite way the stock one faces
i'm pretty sure thats why its so hard to put into reverse
i was just wondering if i should just get the hurst one
or if i should go find another stick at pick-n-pull and just cut it 1/1.5 inches
Old Oct 4, 2006 | 04:52 PM
NEONRT98's Avatar
NEONRT98
Default RE: short shifter
Unless its a family vehicle, whats it matter if its hard for others to put it in reverse? As long as you know how to do it it shouldnt matter. If it were me, I would tell em its a theft deterant :-D
Old Oct 4, 2006 | 04:56 PM
95neonriceeater
hahahahahh
yea
that sounds good
Old Oct 4, 2006 | 08:17 PM
rrwertz's Avatar
rrwertz
which type of ss is it? I've never heard of Sport.
I have a b&m that's cut, and reverse is not a problem. 3rd gear is more of a pain, mostly at the track though.
Old Oct 4, 2006 | 10:06 PM
spudsterier's Avatar
spudsterier
when i put my short shifter in it was a little hard to get into reverse...then i looked at it and the bushing for the cable on the passenger side was rubbing on the shifter base frame.....so i sanded the bushing down a little and now it doesnt have a problem.....
Old Oct 5, 2006 | 01:05 AM
95neonriceeater
my ss is exactly like a b&m but i got it off ebay
i'll see the bushing thing when im the only that drives it again
Old Oct 5, 2006 | 01:17 AM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
Then its not a short shifter, but rather a cut shifter. There is a difference.
Old Oct 5, 2006 | 01:21 AM
spudsterier
i like my hurst...i wouldnt want the throw any longer or any shorter....its perfect
Old Oct 5, 2006 | 05:22 AM
95NeonJS's Avatar
95NeonJS
ORIGINAL: das2123
What is the advantage of a short shifter? over a cut shifter? I've always wondered. My buddy's is cut, mine is an actual sts. What do I have that he doesn't? Besides less money in my pocket.
Old Oct 5, 2006 | 10:18 AM
spudsterier
a cut shifter just lowers the handle hight and movement you arm has to make....
sts actually moves the selection of the gears to a closer ratio, while the height is still lower and you dont have to move your arm as much.....
if you remove your center console and your buddies and move your shifters side to side, the sts will have a shorter distance traveled
