help engine is popping
Old Oct 6, 2006 | 12:21 AM
das2123's Avatar
das2123
Default RE: help engine is popping
ORIGINAL: NEONRT98
Not if they physically look under the hood :-D
You can block it off and leave the tube and valve there and they wouldn't know any better. But you will have the Code 32, unless you have an aftermarket PCM.
