I need power for cheap
Old Oct 11, 2006 | 04:19 AM
own a peice's Avatar
own a peice
Default I need power for cheap
1998 4door SOHC neon i need a good power upgrade for under $600
Old Oct 11, 2006 | 04:20 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: I need power for cheap
Auto or Man.?
Old Oct 11, 2006 | 04:26 AM
own a peice
auto, like the miles mine has 270,000
Old Oct 11, 2006 | 05:07 AM
95neonriceeater's Avatar
95neonriceeater
DAMN!
id say switch to mtx but there goes 600
take your throttle body to a shop and have it bored out to 57mm
you can get pacesetter hearders for 140
an underdrive pulley for 110
get a 3.0L chrysler caravan intake for a junk yard and build a cold air intake with an exhaust pipe and k&n cone for probably 70-80
maybe find a better cam somewhere
adjustable cam gear ?
mopar performance computer around 250
get a dohc muffler for like 10-20 from a junk yard (i got mine for 7)
just go to www.modernperformance.com
the udp, header, mopar computer and adjustable cam gear is on there
i wish i had 600 just for upgrades...
Old Oct 11, 2006 | 10:19 AM
own a peice
Thanks
Old Oct 11, 2006 | 10:36 AM
own a peice
What computer would you recomend
Old Oct 11, 2006 | 11:56 AM
das2123's Avatar
das2123
ORIGINAL: own a peice
Mopar PCM! Since you have a 96, you will need one for your year car. 95neonriceeater gave you some good advice although I wouldn't worry about the adjustable cam gear just yet. Cheap upgrades are the DOHC muffler, 3.0L intake and ATX TB.
Old Oct 11, 2006 | 12:23 PM
racerx55's Avatar
racerx55
whats with 96 only having its own special PCM anyway? i know the 95's had the small one, then 96 up were the bigger pcm
Old Oct 11, 2006 | 12:58 PM
das2123's Avatar
das2123
ORIGINAL: racerx55
It's the same PCM but the circuit for the fans are different. If someone with a 96 wanted to use a 97-99 PCM they will have to swap pins. I think it's pin#55 in the 96 and pin#18 in the 97-99.
Old Oct 11, 2006 | 04:20 PM
95neonriceeater
hey das
he said his was an auto so he doesnt need the atx tb!! haha
thats why i told him to go to a machine shop to get it bored
