door ajar
Old Oct 15, 2006 | 04:40 AM
cjparker12345's Avatar
cjparker12345
Default door ajar
the door ajar light flickers on and off what can i do to override it and yes im sure all the doors are closed
Old Oct 15, 2006 | 06:19 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: door ajar
on car where hte door meets the car, theres a little black button
you can tape it down
one of the plastic pieces fell off and now i have take on the door to push the button in
ghetto...
Old Oct 15, 2006 | 06:29 AM
ZiggyNeon's Avatar
ZiggyNeon
what hes talkin about is if you open all your doors and your looking at the seat from the outside on the bottom right side of the door jam there are 2 black push pins the top is for the dome light and the bottom makes that annoying beeping when u leave the key in acc and have the door open. now unscrew each top push pin one at a time and then put it back in. after each door see if it worked to stop the flickering. why do this? well what happened with one of my push pins....the drivers door....it had a bad or loose ground and the dome light wouldnt come on all the time when i would get in or out. so i just un screwed it then put it back in and now it works like a champ. oh and to by pass it you dont have to tape it down. just take out the screw that holds it in. it wont fall out but...it wont be grounded therefore not working no more flickers or annoying acc key reminder beep gl and lets us know if anything worked
Old Oct 15, 2006 | 05:26 PM
95neonriceeater
you just said what i said in a paragraph
damn i cant explain for ****
hahahahah
Old Oct 16, 2006 | 02:07 AM
DNeon's Avatar
DNeon
do all cars' buttons ground wit the bolt? I had a car that was doin the same thing....was tryna figure out how to bypass it
Old Oct 16, 2006 | 02:59 AM
ZiggyNeon's Avatar
ZiggyNeon
it depends first you have to find it there not all in the same place in example : 1986 mustangs...there push pin is near the door hinges...so first you have to find it then it should be held down with a cross tip ( philips ) head screw. but no guarantees
