caravan intake??
Old Oct 16, 2006 | 01:49 AM
own a peice's Avatar
own a peice
Default caravan intake??
will i have to do any fabrication to put the intake on or will it fit right, and will the intake and throtle fit right
Old Oct 16, 2006 | 01:52 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: caravan intake??
have to trim the battery tray... that should be it... does your Neon have dual rad. fans or just the single one?
Old Oct 16, 2006 | 01:53 AM
own a peice
it has the dual fans
Old Oct 16, 2006 | 01:54 AM
neoncrazy101
might have to do a little more mod. not sure though... mine was only single so....it was easy
Old Oct 16, 2006 | 12:08 PM
das2123's Avatar
das2123
If you have the dual fans, you will probably have to cut the intake tube and put about a 6" piece of exhaust tubing in between to get it to extend far enough to clear the fans.
Old Oct 17, 2006 | 04:21 PM
95neonriceeater's Avatar
95neonriceeater
how can you tell if it has dual fans?
i'm not home to check my neon but i was just wondering if there were certain years, engines, models that had it
just so when i build my cai i dont cut it in half when i dont have to
Old Oct 17, 2006 | 05:04 PM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
Uhhh...just look at your radiator. If it has 2 fans, then it's a dual fan radiator.
SOHC's have the single fan and if the car didn't come with A/C it would have the single fan.
Old Oct 17, 2006 | 05:15 PM
95neonriceeater
hahah well my car came with a/c
but the fan stopped working last week
i've had to drive around with my windows down in the cold so my windows dont fog up
Old Oct 17, 2006 | 05:21 PM
das2123's Avatar
das2123
Fuse and relay been checked?
Old Oct 17, 2006 | 05:43 PM
95neonriceeater
not yet
i think master mechanic father is gonna take a look at it this weekend
if he hasn't already
