Rebuild questions
Old Oct 16, 2006 | 11:18 PM
spudsterier's Avatar
spudsterier
Default RE: Rebuild questions
no...thats too high of compression....for a turbo you need to run sumwhere in the 8.8:1 range
Old Oct 17, 2006 | 01:03 AM
pimpberetta's Avatar
pimpberetta
Well, there has always been that debate drive like you stole it, or baby it.
Personally, have broken in a few engines, and by no means did I baby it. I didn't rev the **** **** out of it, but it wasn't driving like a nun.
If it was built properly, then you shouldn't have any problems with it.
If you run it harder at the start, it will seat the rings faster and lessen break in time needed.
Read THIS LINK solid information.
Suggestive reading.
Old Oct 17, 2006 | 03:03 AM
HabitatHxC's Avatar
HabitatHxC
ya i read that link before, but i wanted some neon fellas expiriances! Thanks alot!
Old Oct 17, 2006 | 05:00 AM
racerx55's Avatar
racerx55
Das thanks for the specs!
Old Oct 17, 2006 | 02:50 PM
das2123's Avatar
das2123
ORIGINAL: pimpberetta
I've read that and still would like to see a comparison between the same engines showing it's better. Until then...I'll continue to beak-in my engines the ol' fashioned way.
Old Oct 18, 2006 | 02:25 PM
racerx55's Avatar
racerx55
now if you hoan the cylinders the right way you wont have to worry about all that, new engines have a finer hoan... whatever, yours isnt a new engine, its gonna have a rough hoan anyway if you do it yourself or take the block and have it done at a machine shop
