speed...
Old Oct 19, 2006 | 05:20 AM
95neonriceeater's Avatar
95neonriceeater
Default speed...
i think my speedometer is off by around 3 mph
anyone know how to fix it?
Old Oct 19, 2006 | 05:42 AM
racerx55's Avatar
racerx55
Default RE: speed...
buy tires the right size for the car
Old Oct 19, 2006 | 06:07 AM
95neonriceeater
i just got new tires that are the right size and everything
i have the stock hubs on
i want rims
Old Oct 19, 2006 | 06:28 AM
racerx55's Avatar
racerx55
it should be right then
if its not then the speedo is probly just tired
Old Oct 19, 2006 | 09:58 AM
spudsterier's Avatar
spudsterier
the neons speedometer is ran by a speedo gear inside the trans....so the only things that might make it off would be the tires, speedo gear itself, cluster, and pcm(though the pcm shouldnt make a difference)
just out of curiosity, what size tires you got on there???
Old Oct 19, 2006 | 11:34 AM
99 Neon's Avatar
99 Neon
hey your not as bad as me sometimes my speedometer just doesnt work all together stuck at 0 of course the cops dont believe me when i tell them that =[
Old Oct 19, 2006 | 01:10 PM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
Why do you think its off?
Old Oct 19, 2006 | 01:27 PM
neoncrazy101's Avatar
neoncrazy101
ORIGINAL: 99 Neon
easy fix... here ya go
that should fix your problem.
Old Oct 19, 2006 | 03:31 PM
95neonriceeater
well i go back home tonight
so i'll either check tonight
or before i leave for work tomorrow morning
Old Oct 19, 2006 | 03:34 PM
FyreDaug's Avatar
FyreDaug
Ill be able to check how much mine is off, but im running 155/70/13 blizzaks on the front, so ofcourse its gonna be off. I think its about 6-7kmh. But ill be able to check once the carputer goes in, its got streets and trips 2006, (gps) so it also shows how fast im going, and how many satellites im connected to
