bolt pattern
Old Oct 19, 2006 | 07:50 PM
iwalton63's Avatar
iwalton63
Default bolt pattern
Does anybody know about or ever heard of the adapter thing to go from four to five lug bolt pattern.
if so, Where do you get them and about how much are they ?
Old Oct 19, 2006 | 07:51 PM
spudsterier's Avatar
spudsterier
Default RE: bolt pattern
most reliable way to do it is to get new brakes and hubs for a 5 lug
Old Oct 19, 2006 | 07:55 PM
iwalton63's Avatar
iwalton63
how much does that run... and would the 5 lug brakes just go right on or what?
Old Oct 19, 2006 | 07:57 PM
spudsterier
sumone said you need the spindles too.....but i dont know....i have the spindles and wheel hubs
maybe check autozone
im sure sumone will reply with whats needed, unless you would rather just use the spacers
Old Oct 19, 2006 | 08:00 PM
iwalton63's Avatar
iwalton63
well...
i would get the spacers..but..i will be needing new brakes pretty soon anyway.
so i would rather just go with all new brakes, and whatever else is needed.
but ya does anybody know what all is needed to completely change that?
Old Oct 20, 2006 | 03:02 AM
das2123's Avatar
das2123
ORIGINAL: iwalton63
They are called wheel adapters or something like that, but I would not recommend them at all.
4 lug vs 5 lug
Old Oct 20, 2006 | 08:00 AM
racerx55's Avatar
racerx55
rear bearing/hub assembly for a 5 lug will go right on, the front you grab spindles rotors and calipers from a 5 lug car and replace the whole deal, unbolt the ball joint & 2 strut bolts & take the whole shot off a donor car,CV splines are the same for either one, adapters suck , theyre dangerous in my opinon
the reason you have to change the whole spindle is because the rotors are larger diameter on the 5 lugs, calipers and brake pads are different also
Old Oct 20, 2006 | 11:28 AM
spudsterier
i have extra spindles, fron calipers, and 5 lug hubs....just need new wheel bearings
a friend of mine had a grand-am that he put the wheel adapters on so he could use a nice set of chrome rims off his other car on it.....they worked good, until he was driving down the road and was passed by his own tire when the adapter broke
adapters are basically made just for looks.....they cant be trusted if you race the car or drive it hard.....or drive it at all for that matter
