DOHC Head on a SOHC Block
Old Oct 13, 2009 | 01:06 PM
  #61
bg1995redneon's Avatar
bg1995redneon
I didn't misread the thread. I turned it into a raceoff as a joke because if you casually read the thread, it looks like you two were dissing each other....so....shutup and race!
Sorry to be too subtle with my humor. I'll go play with my "stock" car now....
Old Oct 13, 2009 | 03:59 PM
  #62
Nuklhed074's Avatar
Nuklhed074
LOL read the whole thread and you all are quite knowledgeable being said i want advice. so my 95 sohc i should leave alone and but dohc pistons in it and a dohc pcm and then get a tune cause at my college unoh i can tune my vehicle would this be my best bet plus my alum underdrive header full straight piped exhaust to a muffler and a cold air no power steering or a/c i should be puttin down a lil power right?
Old Oct 13, 2009 | 11:55 PM
  #63
Ghost Neon 2's Avatar
Ghost Neon 2
All those mods sound good, save the dohc pcm. It does have a different spark and fuel curve that is useful, but the extra fuel is not necessary. Save that for last. The neon runs rich as it is.
Old Oct 14, 2009 | 02:12 AM
  #64
Nuklhed074's Avatar
Nuklhed074
sweet thanks much i also found a cheap throttle body spacer also do those help alot on the neons?
Old Oct 14, 2009 | 11:29 PM
  #65
Ghost Neon 2
Certainly is not going to hurt. Run it.
Old Dec 2, 2010 | 04:38 PM
  #66
gpc31's Avatar
gpc31
So ive read this thread and I have a few questions.
1. Is it possible to put a DOHC neon head on a 2000 SOHC block?
and
2. If it is possible could I use the DOHC intake manifold with it?
Old Jan 26, 2011 | 01:02 PM
  #67
advance's Avatar
advance
i just did that swap but my block is from a 2001 acr and the dohc head is from a 98 r/t so no problems with valves but i have not lost compression if any thing ive gained no i dont plan on turbo my car but if you want to do a dohc on a sohc block find a 2000 - 2005 acr or r/t block **** can the 95-99 sohc block for all motor apps
Old Feb 13, 2011 | 09:49 PM
  #68
das2123's Avatar
das2123
You can't use 2003+ blocks in 1st gen neons without significant work.
gpc31, there is no difference between a SOHC block and a DOHC block. The difference is the pistons. There is a difference between the heads. So yes, you can use a DOHC head on a 2000 block and you would have to use the DOHC intake and exhaust manifolds along with it.
Old Oct 29, 2011 | 04:42 PM
  #69
kathybrj's Avatar
kathybrj
Doing the DOHC head on the SOHC block at home now. Thanks for this thread folks. It's been a HUGE help!
Old Feb 5, 2012 | 01:46 PM
  #70
Wally King Jr. #76's Avatar
Wally King Jr. #76
Default If I am changing from a sohc to a dohc, will i have to change the pcm to a dohc pcm
do i change from a sohc to dohc during a head swap from a sohc to dohc
, and is there a rpm curve difference in the two pcm's?
