DOHC Head on a SOHC Block
Old Feb 5, 2012 | 01:53 PM
  #71
das2123's Avatar
das2123
Originally Posted by Wally King Jr. #76
do i change from a sohc to dohc during a head swap from a sohc to dohc
, and is there a rpm curve difference in the two pcm's?
I assume you are asking if you switch pcms when doing the swap. If so, then yes it would be a good time but not completely necessary. Read the FAQs at the top of the forum for more info on the pcms.
Old Jul 30, 2014 | 12:07 AM
  #72
protivakid's Avatar
protivakid
Does the list in the 1st post apply if I want to put a sohc head on a dohc block?
Other issues I may run into?
Old Aug 2, 2014 | 05:21 PM
  #73
das2123's Avatar
das2123
No, it doesn't.
