would an atx throttle bodie w/out cruise work on a mtx w/cruise. if i didnt want to keep the cruise. and what do i have to do to get rid of the cruise control.?
it will work and you dont HAVE to get rid of the cruise......if you get an ATX throttle body, just get one from the same year....then you can still use the cruise
use the shaft out of the MTX throttle body, and the spring, take off the TPS, take out the snap ring under it, take 2 screws out of the throttle plate, pull the plate out, then the shaft comes out, be carefull not to twist them off if its older and cruddy, you might have to work the screws back & forth quite a bit to get them out in once piece
