shifter
Old Oct 29, 2006 | 10:30 PM
mmench's Avatar
mmench
Default shifter
does a neon r/t come with a screw on shift **** or a set screw type?
Old Oct 29, 2006 | 10:35 PM
spudsterier's Avatar
spudsterier
Default RE: shifter
all 5-speeds come with a press on shift ****.......about 2 inches below the top of the boot there is a small pin on each side of the shifter handle.....on the bottom of the ****, there are 2 plastic retainers.....if you pull the boot down, you can actually see it
Old Oct 29, 2006 | 10:36 PM
mmench's Avatar
mmench
Default RE: shifter
ok thnx
