water in trunk and rear floor
Old Oct 30, 2006 | 12:58 AM
racerx55's Avatar
racerx55
Default water in trunk and rear floor
will the tail light gaskets leak water into the trunk? my pass. side the steel around the gasket is bent from taking a hit to the bumper and the gasket doesnt seal up, im thinking thats why my trunk and rear floor pan is flooded[:'(]
Old Oct 30, 2006 | 01:00 AM
winsettz's Avatar
winsettz
Default RE: water in trunk and rear floor
I believe it's a recurring problem with the Neons...don't remember the specifics of it though.
Old Oct 30, 2006 | 01:13 AM
spudsterier's Avatar
spudsterier
what happens is when it rains or you wash the car or whatever, the water runs into the little gutter you see around your trunk lid when its open.....odly enough this little gutter drains right ontop of the taillights.....my car leaks into the trunk too, but not from the taillight seals, if you remove the trunk matt from the floor behind the taillights and look to the side of the car(by the back of the wheel well by the taillights) there is actually a little vent there that goes behind the back bumper cover, there are 4 individual little rubber covers over this vent....well, when the ground is wet the tires kick up alot of water, this water gets aimed right at the vent.....
when my car goes in the garage, im gonna replace the trunk mat with a spare one i have and then silicone over the vents
Old Oct 30, 2006 | 01:51 AM
iwalton63's Avatar
iwalton63
my trunk leaked too...
The lights were aftermarket ones though, and the seal didnt fit as good as the stock one. My firt thought was that vent thing spud was talking about. So I tested it. I laid in the trunk while my friend poured a bucket of water on the trunk lid...and come to find out it was coming from the back of the lights ( like were they screw into). I tried some GREAT STUFF ( that foam crap for pluming and insulating), that didnt work all that well so I ended up getting pissed off enough to just get this stuff call garoilla tape (its a better version of duck tape) and the put that on the drane part like on top of the lights. Now the water runs over the back off the lights, and not down underneath the back bumper.
Old Oct 30, 2006 | 01:53 AM
winsettz's Avatar
winsettz
Gonna try a roll of duct tape first while I scrounge up for something better. It's nearing the rainy season in Southern California...
Old Oct 30, 2006 | 01:57 AM
neoncrazy101's Avatar
neoncrazy101
i just used some clear silicon WORKS GREAT. cheap 2 and really not all that noticable...atleast not like duct tape...
Old Oct 30, 2006 | 02:09 AM
iwalton63's Avatar
iwalton63
the duct tape is balck...and the trunk is shut when i drive anway so you cant see it.
evenwhen it is open its not the noticable...it works..thats the main part, till i fix it for good
Old Oct 30, 2006 | 03:36 AM
racerx55's Avatar
racerx55
i put some goop on it (the stuff you buy called "goop") i hope it works, i got subs in there, box got wet once[&:]
[IMG]local://upfiles/37714/00A173210BF944A2AC7A46D88DC03594.jpg[/IMG]
Old Oct 30, 2006 | 09:55 AM
spudsterier
i had all my cross-overs in the spare tire well, that was before i knew that it leaked though......ruined all 4 of them, luckily a had plenty extra lying around
Old Oct 30, 2006 | 01:24 PM
sid 951's Avatar
sid 951
there's a seal on taillights on bad ones i get some butyl tape for windshields and make a new gasket (look at the car and lamp you'll see how it goes) make a new seal bolt the light in and you're usually good.
