Rear Disc brake conversion
Old Nov 2, 2006 | 11:58 PM
FastNeon84's Avatar
FastNeon84
Default Rear Disc brake conversion
Is it possible to do a rear disc brake conversion on a neon with rear drums...if so, can anyone tell me all the necessary parts i need to do this?
Old Nov 3, 2006 | 01:17 AM
spudsterier's Avatar
spudsterier
Default RE: Rear Disc brake conversion
i did the swap on my wifes 99 sport......you need
rear disc brake assembly....(dust shield, e-brake setup, hub assembly)
e-brake cables that run from the handle to the disc brake assembly.....if you get the setup from sumwhere the cable should alredy be on the rear assembly
rear disc brake lines
rear calipers, pads, and rotors
Old Nov 3, 2006 | 12:09 PM
das2123's Avatar
das2123
All that will cost you around $150-$200 depending on the seller. I have everything you would need for the swap. PM me if you are interested.
Old Nov 3, 2006 | 07:27 PM
FastNeon84's Avatar
FastNeon84
aight cool, thanks man
Old Nov 3, 2006 | 10:39 PM
spudsterier
took me 30min. per side to do the swap
