SOHC Turbo/NOS
Old Nov 3, 2006 | 12:04 AM
FastNeon84's Avatar
FastNeon84
Default SOHC Turbo/NOS
is forged rods/pistons, and a camshaft/camgear enough to run about 14psi on the SOHC as a daily driver?? what more else should i do before i drop this engine in my car?
Old Nov 3, 2006 | 12:36 AM
Ozneon's Avatar
Ozneon
Default RE: SOHC Turbo/NOS
Cant see why you cant run heaps more boost as long as all the rest is up ther with it injectors/turbo/tuning etc
Old Nov 3, 2006 | 01:21 AM
spudsterier's Avatar
spudsterier
to safely do it the forged pistons and rods will work.....but for 14psi i would deffinately upgrade the injectors......you dont NEED the cam gear....personally i wouldnt mess with the timing if this is the route you are gonna go.....
but anyways it should work......but i assume you know that you cant just drop it in there without upgrading the whole fuel system......like the fuel pump, pressure regulator, and return line
Old Nov 3, 2006 | 12:19 PM
FastNeon84's Avatar
FastNeon84
yea i got a walbro 255 fuel pump..and a venom fuel rail.. im looking for some fuel injectors though..still deciding on what size i should go with the injectors..any of yall know where i could get maybe some 35lb injectors for a good price?? but i don't have to do any porting to the block or the head with the mods im about to do??
the only reason i want to run only 14psi is because this neon is my only ride right now..dont want to run into any problems and be taking a cab to work ya kno...hopefully ill be gettin another ride to drive soon..
anways thanks for the info guys...hopefully i will drop this engine in within the next few weeks and post dyno results.
Old Nov 3, 2006 | 03:48 PM
spudsterier
you dont have to do anything to the head.....but, depending on which pistons you get you might have to bore out the block.....the 8.8:1 JE pistons for a turbo motor require the block to be bored .20 over
Old Nov 3, 2006 | 08:58 PM
FastNeon84's Avatar
FastNeon84
ok kool...do u know the price range ill be looking at for a machine shop to bore my block .20 over? cause as a matter of fact my pistons are 8.8:1
Old Nov 3, 2006 | 09:08 PM
Ozneon's Avatar
Ozneon
Ring around ask lots of questions no matter what the comp ratio on pistons are now u wont know till u do a mock assemble your head may have been machined allready and block surface double check everything read lots of books you never stop learning.
Old Nov 3, 2006 | 09:21 PM
FastNeon84's Avatar
FastNeon84
ok thx man...i know that is NOT a pic of a right-hand drive neon......lol[&:]
Old Nov 3, 2006 | 10:34 PM
spudsterier
id like to have that right hand drive neon
when i was considering getting my motor built i went to a local shop and they told me that to get the head resurfaced, retap all bolt holes, bore and hone, and a good internal cleaning would run about $450-$500
Old Nov 4, 2006 | 12:18 AM
Ozneon's Avatar
Ozneon
ORIGINAL: FastNeon84
"WISH IS WAS LHD"
