PCM VIN question 4
Old May 2, 2026 | 01:55 PM
ElkCon's Avatar
ElkCon
Default PCM VIN question 4
Hi all.
I need to get a new PCM for my van...
I have an issue though...
I put a stock 360/harness/46re in my van and when I sent to original PCM (that had the VIN from the donor van) to a rebuilder, he screwed it up and I ended up having to dispute the charge with my CC and the whole relationship went to hell...basically he used my PCM as a core and ordered the wrong one and then tried to blame someone else etc etc...
That was about a year ago.
@alloro I think you are correct about my ABS light being on as I am researching VIN programming. My used PCM is out of a 3500, so the brake would be 4 wheel ABS and the light should come on
So I need to figure out a VIN for the rebuilt PCM I have now...
Can I use my VIN - change the engine digit to 360 V8 (my VIN presently say 6 cyl) - that should work? Correct? that all I see that would need to be changed.
Or should I just make up a VIN or go to the boneyard and find a 2000 360 V8 and recycle that VIN?
Thanks
Old May 2, 2026 | 02:02 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Hard to say since I don't know if the wrong engine is causing the issue or the lack of a 4-wheel ABS system is. This is a good question to ask a PCM programmer.
Old May 3, 2026 | 08:39 AM
What year is your van?
Old May 8, 2026 | 02:02 PM
ElkCon's Avatar
ElkCon
its an 03
@Hey You do you know of one?
Old May 9, 2026 | 08:31 AM
Should just be a matter of programming the PCM for your engine/trans combo, and the correct vin for the Van it's installed in.
Old May 13, 2026 | 07:18 PM
ElkCon's Avatar
ElkCon
anyone know a programmer? I tried to make the VIN for it starting wiht my V6 vin and changing the motor and check digit...
it ran - it ran great...shifted - everything...
but i still had no bus - yes it ran with no bus and none of the guages work...
for now - its a backup - it would get me home...
