Compounds?
Old Nov 3, 2006 | 12:44 AM
neoncrazy101's Avatar
neoncrazy101
Default Compounds?
ok guys i have some questions about compounds... i read somewhere (i think on the .org site) that rubbing compound will help clear up the haze on the headlights...one is that true? with a TON of hard work.... and also what is the difference in rubbing compound and polishing compound? and how do you use the 2?
Old Nov 3, 2006 | 01:41 AM
winsettz's Avatar
winsettz
Default RE: Compounds?
Neonspeed says to clean the headlights with "all purpose cleaner like Simple Green", put water over the headlight and then sand away with 800, 1000 and eventually 2000 grit sandpaper, then to use plastic polish (or plastic cleaner/plastic polish compound)
Old Nov 3, 2006 | 01:46 AM
neoncrazy101
yea that was one of the other ways they said u could do it...theres like 8 or so lol
Old Nov 3, 2006 | 02:17 AM
winsettz's Avatar
winsettz
Most of the methods appear to involve abrasion one way or another and using polish to compensate.
Old Nov 3, 2006 | 04:19 AM
jared6180's Avatar
jared6180
toothpaste helped on my wifes eclipse...a little bit...at least you can see the curves of the dark light housings now!
Old Nov 3, 2006 | 12:07 PM
das2123's Avatar
das2123
Mother's or Meguiars does a good job without all the sanding.
Old Nov 3, 2006 | 09:13 PM
jared6180's Avatar
jared6180
not really sure why i even tried toothpaste...kind of seemed logical at the time!
