my car lunges
Old Nov 3, 2006 | 06:06 PM
snunicycler's Avatar
snunicycler
Default my car lunges
i drive a 96 neon, automatic. when i accelerate, it doesnt go anywhere for a second or two (like it is in neutral or something) and then it lunges forward. it used to only happen if i braked to quickly. now it does it almost every time i come to a stop or if i shift. i dont know much about cars yet. please help.. thanks!
Old Nov 3, 2006 | 06:09 PM
das2123's Avatar
das2123
Default RE: my car lunges
Check your tranny fluid level....I bet ya it's low. Only use Mopar ATF+3 or 4. There are some others that are supposed to meet the type 7176 specs and are: Valvoline ATF for Chrysler, Pennzoil 7176 ATF, and Quaker State 7176 ATF. Do not use Dexron/Mercon ATF in your neon.
Old Nov 3, 2006 | 06:12 PM
snunicycler
ill try it. thanks for your fast response!
Old Nov 6, 2006 | 10:04 PM
winsettz's Avatar
winsettz
Sometimes when I let off the gas while driving at what I think to be low RPM (no tac ;/) it starts to sorta "jump forward" and back, sorta like my car is gasping for breath, goes away when I hit the gas again. Normal or indicative of something?
Old Nov 6, 2006 | 10:06 PM
jared6180's Avatar
jared6180
kind of sounds like a slipping tranny or a tranny with burnt fluid. I would just get a new filter and fluid put in!
Old Nov 6, 2006 | 10:23 PM
winsettz's Avatar
winsettz
"Just".
Bwah, I will check my fluid levels when the car cools down. Burning self not fun.
Old Nov 6, 2006 | 10:50 PM
jared6180's Avatar
jared6180
new tranny fluid and filter is around 150 around here.
Old Nov 7, 2006 | 02:14 PM
das2123's Avatar
das2123
ORIGINAL: jared6180
Wow...thats alot. When I did my last fluid and filter change with Mopar ATF+4 fluid, the total cost was about $50.
Old Nov 8, 2006 | 04:52 AM
Youngstown97Sohc's Avatar
Youngstown97Sohc
From: Youngstown , ohio (muder capital per capita u.s. )
hes probably talking about hacing it done somewhere... thats about right for labor cost and all i guess a little high... its 100 here for tranny flush and 20$ for screen....
and you always check tranny fluid when hte car has ran for a while (i go for a 5 minute drive before i check it to make sure that it gets to run some gears , it warms up faster with friction and torque...
hova
Old Nov 8, 2006 | 04:53 AM
jared6180's Avatar
jared6180
that is what Cottman Transmisson charges
