head replacment question.
Old Nov 4, 2006 | 01:21 AM
98neon's Avatar
98neon
Default head replacment question.
i have a 98 dohc neon w/ a little over 160,000 miles on it and the vavlues got knocked by the pistons and bent the vaulves when the timing belt broke. all but 3 of the vaulves are good and i have had the idea of swapin the whole motor w. a srt-4 motor but i am kinda tight on money and i was wondering if it would be cheaper and easier to replace just the vaulves or the whole head?? plz help thank you
Old Nov 4, 2006 | 01:54 AM
Ozneon's Avatar
Ozneon
Default RE: head replacment question.
There not all that expensive new just got a exhaust valve aroung $11 each genuine mopar there are stainless os valves around set of 16 for $239.95
Old Nov 4, 2006 | 02:13 AM
98neon's Avatar
98neon
can you give the link to that or did you get it locally?
Old Nov 4, 2006 | 02:18 AM
Ozneon's Avatar
Ozneon
http://www.howellautomotive.com/inde...ROD&ProdID=493
Old Nov 4, 2006 | 02:30 AM
98neon's Avatar
98neon
i have another question for you when i took off my exauhst manifold it was cracked were should i get a new one and which one gets the best bang for your buck??
Old Nov 4, 2006 | 02:50 AM
HabitatHxC's Avatar
HabitatHxC
Go with a short or long tube header pick one! there on howell and modern performance
Old Nov 4, 2006 | 05:00 AM
98neon's Avatar
98neon
I am thinking that if I am puttting in new valves that I am going to have to have the valve seats cut. Or am I going to be able to just put them strait in. I am figuring it would be cheaper to get a new head then buy new valves and have the valve seats cut.
Thanks for the info
Old Nov 4, 2006 | 10:31 AM
spudsterier's Avatar
spudsterier
you can just put the new valves in.....
as for the exhaust manifold, if it just has a hairline crack then thats normal....everyone that i have ever removed was like that...
i have a nice loaded DOHC head with 90,xxx miles on it sitting on a shelf in my garage
Old Nov 4, 2006 | 04:39 PM
98neon's Avatar
98neon
you wanna sell it, if so how much you want for it
Old Nov 4, 2006 | 05:42 PM
FastNeon84's Avatar
FastNeon84
those oversize valves require the head to be bored a lil bit correct?
