bigger brakes
Old Nov 6, 2006 | 06:17 AM
95neonriceeater's Avatar
95neonriceeater
Default bigger brakes
so i heard that the disk brakes off of a 2nd gen neon were bigger than the 1st gen
and i was wondering if it was hard to swap
do you just swap the disk/caliper?
i saw quite a few 2nd gen neons at the pick-n-pull
and my front right brake was making a really loud annoying noise the last few days i was driving it
so i might as well swap them to thoughs 2nd gen brakes if it's worth it!
Old Nov 6, 2006 | 09:57 AM
spudsterier's Avatar
spudsterier
Default RE: bigger brakes
is your car a 4 lug or 5 lug????
with the bigger brakes you should have to swap the spindles too
Old Nov 6, 2006 | 05:00 PM
95neonriceeater
it's a 5 lug
Old Nov 6, 2006 | 08:13 PM
spudsterier
you will probally need the spindles to mount the new calipers
Old Nov 7, 2006 | 12:49 AM
95neonriceeater
alright, thanks!
Old Nov 7, 2006 | 02:09 PM
das2123's Avatar
das2123
ORIGINAL: MCarp22
The problem with a caliper upgrade on the neon is that the caliper brackets are cast into the steering knuckle, instead of bolting on like the PT, SRT-4, and other cars use.
With a bolt on bracket, it is much easier to change the caliper, just make a new bracket to position the caliper correctly.
You either need to swap to manual PT knuckles and machine them to fit the strut, or do a bunch of machine work on neon knuckles to remove the cast bracket.
The 2nd gen rotors are thicker and fit.
Old Nov 7, 2006 | 06:00 PM
95neonriceeater
whats all this machine work mumbo jumbo?
Old Nov 7, 2006 | 06:25 PM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
Not worth the effort. I haven't seen anything saying that the calipers are bigger, just the rotors have more mass.
Old Nov 7, 2006 | 06:52 PM
95neonriceeater
didn't you put 2nd gen brakes on your neon?
did you just swap them on?
Old Nov 7, 2006 | 06:59 PM
das2123's Avatar
das2123
I just have the 2nd gen rotors on my car.
