engineProblems
Old Nov 8, 2006 | 05:10 PM
?ishu's Avatar
?ishu
Default engineProblems
Got a 97neon, Since it got to my house it wont start! Bought new gasket valve, fuel pump, battery and starter! I know I'm not wasting $, but it's money I don't have right now. Any suggestions on what else it could be?
Old Nov 8, 2006 | 05:13 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: engineProblems
pull the codes from the engine
Old Nov 8, 2006 | 05:51 PM
hnda8r's Avatar
hnda8r
Or do the ignition trick thing. ON OFF ON OFF ON, and count the flashes. Then let us know.
Old Nov 8, 2006 | 05:52 PM
?ishu's Avatar
?ishu
Do you mean check my CEL?(Check Engine Light) and look up that code or do I litteraly pull something from the engine?
Old Nov 8, 2006 | 05:56 PM
winsettz's Avatar
winsettz
ORIGINAL: ?ishu
The former.
Alternatively, run down to Autozone and borrow their ODB2 reader.
Old Nov 8, 2006 | 06:00 PM
hnda8r's Avatar
hnda8r
You can either just pull the codes with a reader, or you can turn your ignition switch (dont crank) until you see all the lights come up. Then just do this ON OFF ON OFF ON within 5 sec., then literally count the flashes I.E. flash flash flash flash flash pause flash= 51(running lean) or flash pause flash flash= 12 (Battery or pcm was reset),
I know its a lil wierd but trust me it works!!
Old Nov 8, 2006 | 06:03 PM
?ishu's Avatar
?ishu
oKay I'll try that, Thanks!
Old Nov 8, 2006 | 06:07 PM
hnda8r's Avatar
hnda8r
Let us know , we might be able to help. I know this forum has help me out a lot. [8D]
Old Nov 8, 2006 | 08:24 PM
FastNeon84's Avatar
FastNeon84
wow, never knew u could get the engine codes without the OBD2 reader...
Old Nov 8, 2006 | 10:40 PM
das2123's Avatar
das2123
ORIGINAL: FastNeon84
It's in the 1st Gen FAQ's
