turbo W.I.P. pics
srt-4 is only a 5 speed.....they never made a 6 speed
i plan on pulling down the boot....i was thinking of it when i put it on and realized that i didnt like how the boot looked, i was thinking of painting the handle red....but probally not
the clutch is just a stage 1.....got it from ebay, 220.00 shipped so i thought it sounded like a good idea
i like the shift **** and it isnt like the one that MPX sells that looks like the srt4 **** but has the set screw, the actual srt4 **** is a push on and has a retaining clip in it...but it only took a minuite to grind a flat spot on the handle and then cut a little groove in it
i will put up more pics tonite because i hope to have most of the motor back together, then start on the rest of the turbo and gauges
ORIGINAL: spudsterier
how did you manage to get an srt4 confused with a RSX???
which large detail?????
if i can get the **** off of there i will take a pic and show you....but i didnt modify the ****, just the handle....first i had to grind the front of the handle flat...then i took a dremel and cut i little groove in the top front of the handle about 1/8th inch from the top......though it took a couple tries to get the notch right where it needed to be
the **** is on there pretty tight now, i put it on for a trial and had to almost beat it off with a hammer
ok i got some more pics today...
one is of how much room i have between the turbo and the firewall..
there is another of the motor as its been assembled a little more....
one of the front bumper again, but with the intercooler lowered a bit
and the gauge pod after i installed it and painted the front...
and one of the drain fitting in the oil pan
the only problem that i have came accross so far is that the upstream 02 sensor wires need to be extended about 4 inches because the stock srt4 02 housing has the 02 sensor port on the opposite side of the pipe then the stock neons...
[IMG]local://upfiles/29901/1958A21858C14DDD8D611028474DC2EE.jpg[/IMG]
[IMG]local://upfiles/29901/32075565957146D7BE9E5D84E12E495B.jpg[/IMG]
[IMG]local://upfiles/29901/C3D4937DAF914B1F864817E59C6FCD7F.jpg[/IMG]
[IMG]local://upfiles/29901/9D5740E1BD8D424787FB914C1DB1C3B3.jpg[/IMG]
[IMG]local://upfiles/29901/276F89B2EC654139BF7D9CBAC341F451.jpg[/IMG]
