19lbs accel injectors
Old Nov 11, 2006 | 06:53 PM
spudsterier's Avatar
spudsterier
Default RE: 19lbs accel injectors
just connect it to the 1 up-stream 02 sensor....not both
Old Nov 11, 2006 | 09:04 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
It will still be useless without a wideband O2.
Old Nov 12, 2006 | 12:58 AM
neonboy07's Avatar
neonboy07
no i didnt mean i hooked them both up at the same time i tried each of them and i still cant get it too work it wont even bounce back and forth it just it stuck in the red and wont move at all i know i will have too have a wide band but i am just trying too get some what of a reading
Old Nov 12, 2006 | 02:16 AM
NEONRT98's Avatar
NEONRT98
Hook your signal wire to the upstream O2 sensor on the black wire w/ a green tracer... Thats the advice I was given (Thanks DAS) and I agree, the gauge is pretty useles...
Old Nov 12, 2006 | 10:46 AM
spudsterier
i just got mine for sumthing to fill up the 3rd hole in the gauge pod
Old Nov 13, 2006 | 07:44 PM
BlackRT?'s Avatar
BlackRT?
ORIGINAL: das2123
ORIGINAL: neonboy07
yeah i put 19lbs injectors in my 96 sohc with a good bit of bolt ons i was wondering if they was too big because now i get white smoke out of my exhust at idle it resonds good it justs smokes white and if any body knows how about how much hp i got from adding these please respond
Take the injectors out and put the stock ones back in. You don't get HP from adding bigger injectors. You can have all the bolt-ons possible and you won't need bigger injectors, they are for turbo applications.
or if you have a 2.4 swap!!! i have 24lbs injectors
