19lbs accel injectors
Old Nov 10, 2006 | 02:41 AM
neonboy07's Avatar
neonboy07
Default 19lbs accel injectors
yeah i put 19lbs injectors in my 96 sohc with a good bit of bolt ons i was wondering if they was too big because now i get white smoke out of my exhust at idle it resonds good it justs smokes white and if any body knows how about how much hp i got from adding these please respond
Old Nov 10, 2006 | 04:45 AM
FuzzRacer's Avatar
FuzzRacer
Default RE: 19lbs accel injectors
that white smoke isn't a good thing, you might have blown the headgasket. not sure if running lean will cause the white smoke but I know the headgasket will.
Old Nov 10, 2006 | 10:53 AM
spudsterier's Avatar
spudsterier
not sure how much power you will get, but in order to get the max output from the injectors you need to upgrade the fuel pump and regulator....otherwise the injectors are still gonna get almost the same amount of fuel as the stock ones
Old Nov 10, 2006 | 11:58 AM
das2123's Avatar
das2123
ORIGINAL: neonboy07
Take the injectors out and put the stock ones back in. You don't get HP from adding bigger injectors. You can have all the bolt-ons possible and you won't need bigger injectors, they are for turbo applications.
Old Nov 10, 2006 | 06:34 PM
FastNeon84's Avatar
FastNeon84
yes sir!
Old Nov 10, 2006 | 08:19 PM
neonboy07's Avatar
neonboy07
yeah i wasent goona keep the injectors in but i ported my head and i am running lean?
Old Nov 10, 2006 | 09:12 PM
FastNeon84's Avatar
FastNeon84
get a air/fuel ratio gauge. but it is a chance you might be running lean. get it checked out before it causes more serious problems.
Old Nov 11, 2006 | 12:33 AM
das2123's Avatar
das2123
ORIGINAL: neonboy07
You are probably running rich with those injectors in there. How is your gas milage now?
Old Nov 11, 2006 | 02:05 AM
hnda8r's Avatar
hnda8r
ORIGINAL: FastNeon84
Air/Fuel guages are worthless unless you have a wideband O2. It might give you a reading but its not very accurate. I had one in my Supercharged Toyota Solara, and all it did was go back and forth like a fricken circus. Until I got a wideband and it was all good.
Old Nov 11, 2006 | 02:38 PM
neonboy07's Avatar
neonboy07
really havent drove the car i am in the middle of painting the car so i have no clue about the gas milage i have a air/fuel gauge i tried too hook it up too both o2s but i can get a reading any u guys know what 02 or whick color wire too hook it to ?
