E- Brake Adjustment??!
Old Nov 11, 2006 | 03:05 PM
LivinNstiX's Avatar
LivinNstiX
Default E- Brake Adjustment??!
How does one adjust the e-brake on the neon.. i looked in the hanes book but its useless
i have 4 wheel disk and i haven't taken the back tires off to look in yet
Thanx
p.s. MTX, when parking on a hill i just hope the transmission doesn't pop outta gear for some reason
Old Nov 12, 2006 | 05:07 PM
Only Another's Avatar
Only Another
Default RE: E- Brake Adjustment??!
i have the same problem with mine. sometimes the actual break will get worn down or so on the back, but as for tightening the cable, mine needs it because it only engages at the very top notch, and nothing up till then
Old Nov 12, 2006 | 06:18 PM
FyreDaug's Avatar
FyreDaug
I thought you can just go crazy pulling it up and down and it auto adjusts?
Old Nov 12, 2006 | 07:57 PM
winsettz's Avatar
winsettz
Supposedly you push down the button, pull all the way up, then drop back down quickly, over and over again to adjust the tension on the lever itself. If that don't work, I think there's another thing you do to the drum itself...
Old Nov 14, 2006 | 01:34 AM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Is this really how you adjust it or are you just bull$#!ttin? If you are just joking, how do you really adjust it?
Old Nov 14, 2006 | 02:37 AM
winsettz's Avatar
winsettz
That's what I've heard on other forums. I've tried it and it appears to work; it could be placebo.
Old Nov 14, 2006 | 04:09 AM
Only Another
What you can do to tighten the tension is take off the wheel, then the disk and inside there should be a nut to adjust the tension of the e brake...
Old Nov 14, 2006 | 04:47 AM
winsettz's Avatar
winsettz
Saw that too, it's in the FSM...Chapter Five, page 24 I think (for the '97 model year FSM).
My Haynes is in the car right now... ;/
Old Nov 14, 2006 | 05:27 PM
FyreDaug's Avatar
FyreDaug
if you have drums you can go through an manually adjust them, or better yet, take the wheel off, get some brake cleaner, spray that bitch clean then re-assemble, after adjusting them a little (I went 2 clicks on both of mine after cleaning it) e-brake didnt seem to feel any diff but brake seemed to start a little higher in pedal travel. As for e-brake I wasnt joking
