now my egr valve...will it ever end?
Old Nov 27, 2006 | 02:45 AM
winsettz's Avatar
winsettz
Default RE: now my egr valve...will it ever end?
EGR cleaning isn't too bad. unscrew the two 12mm bolts holding the EGR to the engine, I think two eight or nine mil bolts hold the EGR to the EGR/TB pipe. Disconnect transducer stuff, lift EGR off (don't mess with the gaskets, they look frail!)
Old Nov 27, 2006 | 02:58 AM
jared6180's Avatar
jared6180
why not just get a egr block off kit?
Old Nov 27, 2006 | 10:18 AM
spudsterier's Avatar
spudsterier
ORIGINAL: winsettz
10mm bolts that hold the EGR to the engine
8mm bolts for the EGR tube
you can take almost an entire neon apart with a 10,13,15 mm wrenches....there arent many bolts that are 12's or 9's
Old Nov 27, 2006 | 11:29 AM
das2123's Avatar
das2123
ORIGINAL: jared6180
Because it's bad for the environment and some people have emissions check.
Old Nov 27, 2006 | 02:00 PM
jared6180's Avatar
jared6180
in kansas we just have to do a vin check on out of state cars...thats it!!!
Old Nov 28, 2006 | 03:58 AM
winsettz's Avatar
winsettz
Different story in California. Ugh, smogcheck.
Old Nov 28, 2006 | 04:27 AM
jared6180's Avatar
jared6180
I love the fact that nobody tells me my car is to loud(the mustang, the neon is still sock)
Old Nov 28, 2006 | 04:58 AM
FyreDaug's Avatar
FyreDaug
ORIGINAL: neoncrazy101
and just to let u know...it will end sometime...in the future
yeah after everything gets replaced it seems
Old Nov 28, 2006 | 05:00 AM
FyreDaug's Avatar
FyreDaug
ORIGINAL: FastNeon84
if a new one doent cost that much, u should just replace it instead of taking the chance of messing it up, cleaning it with brake fluid...
brake FLUID? I think you mean cleaner
