sohc or dohc?
RE: sohc or dohc?
your not gonna get high performance internals for that much....for $300 you could basically just get new stock pistons/rods....the JE piston/eagle rod combo will run you about $800...but then you also have to get the block machined for the larger bore.....
even the cheaper wiseco piston/eagle rod combo wil still run you about $600
RE: sohc or dohc?
well i want a turbo for my neon but i also am working on a project muscle car....i just want the necessary parts i have the turbo but now i need to find the rest of the parts to get it in....and spud is ur turbo in? how much of a diff does it make?...does anyone know how much hp this will give u? oh and what intercooler did u use?..... i really need a link to find that turbo adapter.........thanks
