Hello everyone new here and need help
Old Nov 15, 2006 | 05:23 PM
das2123's Avatar
das2123
Default RE: Hello everyone new here and need help
ORIGINAL: greekthang
Thank you das2123. I have heard that the tranny is very sensitive and I am scared to mess with it. Its working ok now just wondering if i should mess with it.
Tightening/adjusting the kickdown bamd is easy and simple and should help improve the shifting.
Old Nov 15, 2006 | 05:35 PM
greekthang's Avatar
greekthang
ORIGINAL: das2123
I agree with that totally but i am afraid with changing the fluids das2123. Should I be. My dad has a Caravan and we have had nothing but issue with that thing. Just scared I guess
Old Nov 15, 2006 | 05:39 PM
hnda8r's Avatar
hnda8r
ORIGINAL: das2123
Is there a how to on this, DAS?
Old Nov 15, 2006 | 05:40 PM
greekthang's Avatar
greekthang
ORIGINAL: hnda8r
ORIGINAL: das2123
http://www.myneonspeed.com/howto/how...atxbandadj.htm
Old Nov 15, 2006 | 05:52 PM
das2123's Avatar
das2123
There isn't much to changing the fluid. Loosen the bolts, drain the fluid, pull the pan off, clean it out, scrape off old gasket material, pull filter off, install new gasket and filter, tighten the bolts and add Mopar ATF+4 fluid.
