Help with disc removal
Old Nov 18, 2006 | 08:55 AM
crowbarwillie's Avatar
crowbarwillie
Default Help with disc removal
Hello!
I live in sweden and own a 98 neon. I need to replace the rear discs but i cant remove the old ones. It seems like the handbrake pads is to tight and i cant find the adjustment for the handbrakes. I have ordered a rapairmanual but i takes some time before i get it so i would be glad if anyone could help me with some hints.
Regards
Mats
Old Nov 18, 2006 | 11:22 AM
FastNeon84's Avatar
FastNeon84
Default RE: Help with disc removal
hmm..i would try bleeding the brakes out to get it loose, and refilling the brake fluid when ur done.. but not too sure cause i have rear drums...
Old Nov 18, 2006 | 02:16 PM
Whatsrt4's Avatar
Whatsrt4
There is an adjustor ,behind the backing plate ,.If you follow the e-brake cable you should find it easy.Try backing that off.( the e-brake has it's own pads)The last time I did my brakes I had to use a Hammer and a piece of 2x4 to get the disc off.You can spray it with a bit of wd40 or ? first, just make sure you get all of it off befor re-installing disks.
ORIGINAL: crowbarwillie
Hello!
Regards
Mats
Old Nov 18, 2006 | 02:40 PM
spudsterier's Avatar
spudsterier
make sure your ebrake is off......then beat the rotors with a hammer from different directions
it works
Old Nov 18, 2006 | 09:51 PM
crowbarwillie
Hi
OK! Thanks for the tips! Ill try beat a little harder than before!
Mats
