2.4 crankshaft in a SOHC 2.0 block?
Old Nov 19, 2006 | 04:15 AM
FastNeon84's Avatar
FastNeon84
Default 2.4 crankshaft in a SOHC 2.0 block?
a friend of mine was telling me that its possible to put a 2.4 crankshaft in SOHC block. can anyone verify that this is true? its going to cost me $175 to bore my block out .20 over for the forged SOHC pistons and rods that i have, but i heard you would gain more torque and horsepower using the 2.4 internals, i suppose that my SOHC block has to be bored out to a 2.4L for everything to work correctly. So before i open up my rebuild kit...anyone know which would be better for my turbo setup? and what compression ratio my pistons should be for the 2.4?
Old Nov 19, 2006 | 10:38 AM
spudsterier's Avatar
spudsterier
Default RE: 2.4 crankshaft in a SOHC 2.0 block?
as far as i know the 2.4 internals wont work on a 2.0
i was told that the 2.4 has a different stroke and rod length but im not positive
Old Nov 19, 2006 | 10:42 AM
FastNeon84's Avatar
FastNeon84
yea i just found that out from a few other Neon buddys, i guess my the guy that told me didnt know what he was talkin about...oh well....2.0 it is!
Old Nov 19, 2006 | 10:49 AM
spudsterier
hey atleast it will be less work
Old Nov 19, 2006 | 01:20 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
You are correct on all points there.
Old Nov 19, 2006 | 03:46 PM
spudsterier
i was wanting to find out if the srt4 pistons would work in my motor.......pissed me off that they wouldnt......i was told that the location on the wrist pis is different[:@]
Old Nov 19, 2006 | 09:14 PM
das2123's Avatar
das2123
Nope won't work....if you had a 2.4L engine, they would work
Old Nov 19, 2006 | 09:37 PM
FastNeon84's Avatar
FastNeon84
thanks for the info guys
Old Nov 19, 2006 | 10:51 PM
spudsterier
ORIGINAL: das2123
i know....thats why i dont have them
