which way to go guys
Old Nov 22, 2006 | 11:41 PM
das2123's Avatar
das2123
Default RE: which way to go guys
ORIGINAL: spudsterier
pt is a nice little upgrade
I had one on the car I am parting out and loved it.
Old Nov 23, 2006 | 02:01 AM
scorpio66772's Avatar
scorpio66772
Any ideas on which brand and where to buy it at..?? a PT clutch and what Benefits does a PT clutch over a 2.0??
Old Nov 23, 2006 | 02:02 AM
scorpio66772
And anyone know who has a good Invader body kit for cheap?
Old Nov 23, 2006 | 02:17 AM
das2123's Avatar
das2123
ORIGINAL: scorpio66772
The PT clutch is stronger than the OEM neon clutch and holds more power.
Old Nov 23, 2006 | 04:15 AM
scorpio66772
Got ya thanks will do so... any idea who sells aftermarket hoods other than carbon fiber... or am I just gonna have to add a scoop to a factory bubble?
Id like one like a vader that isnt carbon. not too worried about the weight and I preffer to paint the hood, Never cared for the carbon fiber look.. would be happy for just a fiberglass hood.
Thanks for the info...
Old Nov 23, 2006 | 04:30 AM
Only Another's Avatar
Only Another
can you swap the clutch, rockers, lifters, from the pt into a 2.0 neon dohc with no compatibility problems? what else can be interchanged
Old Nov 23, 2006 | 01:25 PM
das2123's Avatar
das2123
So what makes you think you can't paint over carbon fiber??
ORIGINAL: Only Another
Yes to all.
The wheels.
Old Nov 24, 2006 | 12:14 AM
scorpio66772
nothing just dont want to pay that kind of money for a carbon fiber hood if Im just gonna cover it up....
Another change in plans... I just found out that the engine I was gonna buy has 2 bell housing bolt holes busted on it... (He litterally got run over by a semi. and cracked the trans in 2 and broke the housing holes... and they are next to one another...) next option is to either locate the 2.4 or rebuild the Sohc into the dohc meaning an engine rebuild kit and a head, intake, covers, etc. etc... I sure would like to find a 2.4. What about the comp> do I need a 2.4 or a 2.0Dohc, what about the exhaust header (for the turbos)
I appreciate the help on this I know Im taking alot of your time just trying to weigh my options and dont want to jump into something with only half the info...
Thanks for you time...
Old Nov 24, 2006 | 01:08 AM
scorpio66772
Just researching the 2.4 swap instructions you gave me the outher day... do you know what is meant for (Nemo mount and bracket kit) that he mentions I cant find anything about it...
Old Nov 24, 2006 | 02:55 AM
das2123's Avatar
das2123
Nemo is a guy who made the mounts and ported/polished heads, but is no longer n business. You can get a 2.4 mount adapter from Modern Performance now.
