which way to go guys
Old 11-24-2006, 05:35 AM
scorpio66772's Avatar
scorpio66772
scorpio66772 is offline
Default RE: which way to go guys
If Im swappin to a 2.4 what year is recommended for the 2.4 and do I need the 2.4 comp or will the 2.0 dohc or sohc work(one post said that a dohc will run a sohc just with a little high of an idle) I plan on making a few calls and visits in the morn to look for a 2.4 so get back As Soon As Possible..... Thanks once again Sensae
LOL
  #22
Old 11-24-2006, 11:07 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
try and find a 2.4 out of the late 90's plymouth/chrysler cloud cars.......stratus, cirrus, or breeze
  #23
Old 11-24-2006, 02:03 PM
scorpio66772
what about the computer?
Is there a prob with using a 2000+ engine?
  #24
Old 11-24-2006, 03:08 PM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: scorpio66772
You would use a 1st gen neon PCM. You can use the 2000+ engines, but then you can/may start running into compatibility problems.
  #25
Old 11-24-2006, 04:59 PM
scorpio66772
Got ya.. Thanks...
Now if only I can find the 2.4
  #26
Old 11-30-2006, 01:56 AM
scorpio66772
Hey I just found a post on ***** about an engine swap "2001-02 Magnum motor" my question is what Magnum engine are they talking about.. just once again checking all my options...
  #27
Old 11-30-2006, 02:01 AM
das2123's Avatar
das2123
das2123 is offline
The magnum engine is the SOHC 150HP engine that came in the 2nd gen ACR's and R/T's.
Quick Reply: which way to go guys
