Cruise Control problem
Old Nov 21, 2006 | 12:38 PM
Only Another's Avatar
Only Another
Default Cruise Control problem
what would cause the cruise contoll to stop working? The only thing i changed was take out the cat, change the exhaust headers, and put in a CAI. I must have bumped off a vacumm line or something right? If it helps, its a 1999 dodge neon r/t mtx
Old Nov 21, 2006 | 01:15 PM
das2123's Avatar
das2123
Default RE: Cruise Control problem
I would double check all vacuum lines and connections.
Old Nov 21, 2006 | 02:46 PM
LivinNstiX's Avatar
LivinNstiX
The cruise control stuff id under the battery box so its possible that u bumped something when u installedt he CDI if u have the battery box removal kind
Old Nov 21, 2006 | 03:54 PM
spudsterier's Avatar
spudsterier
my cruiser stopped working a while ago.....but my CC unit that has the cable that goes to the throttle body ended up going out
Old Nov 21, 2006 | 04:56 PM
FastNeon84's Avatar
FastNeon84
never heard of a 5spd neon with cruise control.....
Old Nov 21, 2006 | 07:10 PM
Only Another
yes i do not believe they are common, but if you want pictures of it just tell me...i moved the battery to the back but i have the battery box still there with a big hole cut in it
Old Nov 21, 2006 | 07:30 PM
spudsterier
every 5-sp ive ever owned has had cruise
Old Nov 21, 2006 | 08:00 PM
FastNeon84's Avatar
FastNeon84
Dang, thats just something i never seen before..
Old Nov 21, 2006 | 08:38 PM
95neonriceeater's Avatar
95neonriceeater
i want CC
Old Nov 21, 2006 | 11:38 PM
spudsterier
i liked having mine.....but it hasnt worked in a few monthes and now i took it all off
