Grinding brakes
Old Nov 22, 2006 | 02:43 AM
QuiK615's Avatar
QuiK615
Default Grinding brakes
sound from the front end when i slow down, obviously the brakes, makes a griding sound thats mostly heard from inside the car. started after i accedently put it in reverse rather than neutral and revved going like 3mph. Im thinking i probly just knocked something loose eather that or the brakes suck. How much am i looking at for repairs? can i do it myself?
Old Nov 22, 2006 | 02:45 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: Grinding brakes
the day before my water bump blew my front right brake sounded like that
but my brakes have 250k miles on them..
i'm getting new rotors eventually
that is probably what you need as well...
i don't know how much it is
but there is a post that was up recently explaining how to swap them i think
Old Nov 22, 2006 | 10:04 AM
spudsterier's Avatar
spudsterier
if its just the brakes then new rotors can run about 25.00-60.00 or so.....and pads can range from 15.00-50.00 or so...
get decent rotors and expensive pads
Old Nov 22, 2006 | 12:05 PM
QuiK615's Avatar
QuiK615
is it a DIY fix?
Old Nov 22, 2006 | 01:47 PM
spudsterier
if its the brakes then yes....
Old Nov 22, 2006 | 08:06 PM
QuiK615's Avatar
QuiK615
took it to the mechanic...
needs 2 front rotors 2 front pads rear alignment and piston... total of 500 [:@]
Old Nov 23, 2006 | 12:05 AM
spudsterier
a piston??? for what??? maybe the caliper???
Old Nov 23, 2006 | 04:20 AM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Did the mechanic check the muffler bearings? Those need lubing every 3000 miles.
Old Nov 23, 2006 | 09:41 AM
spudsterier
i thought they were supposed to be redone at 3500 miles not 3000
Old Nov 23, 2006 | 12:57 PM
FastNeon84's Avatar
FastNeon84
whats a muffler bearing??? lol[&:]
