so close....yet so far
Old 11-29-2006, 12:41 PM
sid 951's Avatar
sid 951
sid 951 is offline
Default RE: so close....yet so far
a lot of guys ditch the banjo fitting and go to an fittings for the oil feed lines, another option for you-check the local bone yard for a caliper feed bolt of the same size or even a local auto parts.
Old 11-29-2006, 04:06 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
i have been to every parts store in the area and no one has a crush washer of the size i need....they are either barely too small or way too big....
as long as the line ends up comming with them, then i will have em tomorrow or friday....which will give me plenty of time to get everything else done.....
i was thinking of getting the AN fittings, but thats just longer i will have to wait for parts and more money to spend....that i dont have right now[&:]
Old 11-29-2006, 09:19 PM
sid 951's Avatar
sid 951
sid 951 is offline
got ya spud-projects like this can sometimes nickel and dime you to death kinda sucks you couldn't find the right washers
Old 11-29-2006, 09:22 PM
FastNeon84's Avatar
FastNeon84
FastNeon84 is offline
hope everything works out for ya real soon....when u get done, you should put a sound clip up of how your car sounds after the install is done
Old 11-30-2006, 12:46 AM
spudsterier
my digi. camera only takes pics.....but the wife is getting me a new one for christmas that take videos.....so yeah, i will definately put one up
i got my new radiator this mornin.....now i need a new lower radiator hose...maybe tomorrow i will get it
the regulator is a hosed up...
so now i am waiting on the washers, hose, and i need to figure out how to wire up the map clamp....it should be redy to go by friday....hopefully
Old 11-30-2006, 12:48 AM
FyreDaug's Avatar
FyreDaug
FyreDaug is offline
rads arent expensive from a bone yard, or do you have an aftermarket one?
Old 11-30-2006, 01:05 AM
spudsterier
i bought a new one a few monthes ago and it started leaking.....so i just got it replaced for free....
its just a stock radiator...but when it comes to things like this, i dont like getting used ones
Old 11-30-2006, 11:28 PM
spudsterier
ok so i hooked up the map clamp, got the air filter mounted, regulator is plumbed and hooked up, as long as i get the crush washers tomorrow, i will be able to start/tune it a little.
here are some newer pics of it almost redy to go
i also got bored the other day and bent myself a new antenna since i was getting tired of the other one.....let me know what you think
and i better pic of the gauges
[IMG]local://upfiles/29901/F72A9C3E562C4970969E9D7C1921357F.jpg[/IMG]
[IMG]local://upfiles/29901/04060435953F4E15BDF0AC6315720B21.jpg[/IMG]
[IMG]local://upfiles/29901/E6259F4B96D64493BF7B195AD4AE84A8.jpg[/IMG]
[IMG]local://upfiles/29901/CDA91CDA9FA6466F9C2B5D3E746B1D8D.jpg[/IMG]
Old 11-30-2006, 11:29 PM
spudsterier
and a few more
[IMG]local://upfiles/29901/5E2AE98D586B4B61BD38DCCB22DA089D.jpg[/IMG]
[IMG]local://upfiles/29901/4E9018C8827D425DA5D38DC08E755949.jpg[/IMG]
[IMG]local://upfiles/29901/5244BD80EB2D4DF7B39BD5689AF38F79.jpg[/IMG]
Old 11-30-2006, 11:42 PM
Only Another's Avatar
Only Another
Only Another is offline
What is this? and your antenna is sweet
