Headlight Problem
Old Nov 29, 2006 | 12:42 AM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Default Headlight Problem
Is it possible for a headlight to slowly go out? I mean, they seemed to be brighter before, then last night I was driving home and it seemed like they weren't even on. I actually pulled over because I thought that they had both blown out. My wife was in front of me and she said that when my high beams were on they looked like low beams and my low beams looked like they were barely working. I know that they are a little hazy from being old but I never noticed it like this before.
Old Nov 29, 2006 | 12:57 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: Headlight Problem
my lights were like that for a while but it was only because the lenses were dirty
Old Nov 29, 2006 | 03:50 PM
93 tona's Avatar
93 tona
take it azone, and have hem check your alternator
Old Nov 29, 2006 | 04:09 PM
spudsterier's Avatar
spudsterier
was it wet outside?????
Old Nov 29, 2006 | 06:21 PM
das2123's Avatar
das2123
Weak battery can cause the lights to dim and/or the alternator not charging correctly. Also, make sure they are plugged in all the way.
Old Nov 30, 2006 | 12:33 AM
spudsterier
one of mine ended up dimming a bit and i found out that it was because the bulb sockets were starting to go bad......after i replaced the sockets they were fine
Old Nov 30, 2006 | 02:18 AM
scramer05's Avatar
scramer05
test your alternator, battery, and your sockets. mine had the same problem.
Old Nov 30, 2006 | 10:09 AM
spudsterier
if the sockets look burnt then you can get new ones from wal-mart for about $4.00
Old Dec 2, 2006 | 12:03 AM
IGottaFreeNeon
It was raining, now that you mention it. Can I do some kind of load test or something for the alternator?
Old Dec 2, 2006 | 08:12 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
yes, my sockets went bad one time cause i had a to high of a wattage bulb in there i dont remember what but it slightly melted the wire just as it enters the socket been like that for a year i just ahve a rag stuffed in there that keeps the connection. i keep forgetting to get them at the junk yard when i go
