full drag neon ***tube chassis***
Old Mar 30, 2007 | 07:07 PM
  #121
FastNeon84's Avatar
FastNeon84
Default RE: Well, my account is gone, so here we go...
ORIGINAL: tdizz07
whats so bad about honda's?
i would come on a dodge forum asking that question.....lmao
Old Mar 31, 2007 | 01:47 AM
  #122
Dazzellerr's Avatar
Dazzellerr
first six pics are the medium first coat and second heavy coat...
this is what happens when someone turns off the air compressor and leaves and your air pressure drops to nothing while your painting...
next 7 pics are the final coat and letting it sit to dry....
not too bad for my first ever painting of a car, runs will buff out along with a final buffing to smooth it all out.
car is a bright white tho, pictures dont do it justice! cant wait til it is all done and dry and all the masking is off (taillights, door handles, ect)
Old Mar 31, 2007 | 02:17 AM
  #123
formula21's Avatar
formula21
looks nice
Old Mar 31, 2007 | 02:18 AM
  #124
dcmcguy's Avatar
dcmcguy
WOW!!! NIIICE JOB MAN!!! keep it up! this thing is gonna be one of the swetest neons ever! your doing an unbelievable job on the motor! well, keep up the AWESOME work!
Old Mar 31, 2007 | 09:38 AM
  #125
FastNeon84's Avatar
FastNeon84
just plain buffing wont get those runs out.....you need some 600 or 800 grit and wetsand them out.....you may have to reclear that section if you sand too much....but if you dont then the buffing compound should bring the shine back--just thought id put my .02 in since im majoring in auto body repair & paint
Old Mar 31, 2007 | 09:39 AM
  #126
FastNeon84's Avatar
FastNeon84
oh yea.....use a3m sanding block when you do get the runs out
Old Apr 1, 2007 | 09:45 AM
  #127
Dazzellerr's Avatar
Dazzellerr
lol, it's a single stage paint, and if i used that rough of a grit, i would be repainting it. i think i will stick to the 1k-1500 grit paper and buff it out like i have been told by my auto body friend who has his own business n all. sand it with the really super fine paper, then using a buffer, buff to a nice sheen along with the rest of the car to give the paint a nice even surface instead of the little "fisheyes" that occur on single stage paint.
i have no doubt you know your stuff, but 800 grit will do nothing but take the paint right off and need to be spot repaired, no thanks on that, i have til the 7th of april to get this all done and still have a few more things to do like get the brakes figured out, battery tie down, boost turned up and tuned, ect.
Old Apr 1, 2007 | 02:12 PM
  #128
FastNeon84's Avatar
FastNeon84
o i didnt know it was single stage paint....we only use basecoat-clearoat at my school...
Old Apr 2, 2007 | 11:51 AM
  #129
racerx55's Avatar
racerx55
1500 is even a bit rough on single stage, as long as you have enough paint on you dont go through to the primer
Old Apr 2, 2007 | 02:48 PM
  #130
Dazzellerr's Avatar
Dazzellerr
yeah, i have 1 meduim wet coat, then 3 heavy wet coats. i am going to be very carefull on it.
