speedo isnt working
Old Nov 30, 2006 | 02:32 PM
blackattack's Avatar
blackattack
Default speedo isnt working
well i bought a used gauge cluster off ebay from a 95. Put it in and the speedo and odemeter doesnt work still. The right side of the gauge cluster connecter isnt their, they singly wired them in and i wondered if they mixed them up. Anybody now the correct colors in order? And somebody mentioned my vss is bad. Where is that located?
Old Nov 30, 2006 | 02:50 PM
Only Another's Avatar
Only Another
Default RE: speedo isnt working
When my speedo went bad, it wasnt actually the speedo...the plastic gear inside the tx that spins the speed sensor slipped up so i had to take it out and stick it back in...but if your tack works still, then that could be the problem...to find out ( only do this if the MPH needle slightly bounces or dosent move but your rpm are still functional) take off the speed sensor that is bolted on the tx, and reach your finger down there and try to wiggle a gear around
Old Nov 30, 2006 | 03:06 PM
neoncrazy101's Avatar
neoncrazy101
could still be the gauge cluster being bad...here's a thread on how to fix it... right here
it could also be your speed sensor...when i got a new cluster it still didn't work so i decided to run the codes and it said no signal from speed sensor...turns out the shop we took it to to get the clutch replaced didn't connect the speed sensor again[:@]
Old Nov 30, 2006 | 03:29 PM
blackattack
where is teh speed sensor? is it on top of tranny to the left of the downpipe right?
Old Nov 30, 2006 | 03:56 PM
spudsterier's Avatar
spudsterier
on top of the tranny straight down below the brake booster......if you take it out then becareful.....the gear is connected to the sensor by 2 small clips.....dont try and pull it off unless its out of the car.....and the gear is barely smaller then the hole it goes in, so pull it out gently
Old Nov 30, 2006 | 03:57 PM
neoncrazy101
on the 5-speeds its right on the bottom facing up... that is if your looking from the engine bay and u look down and over u will see it...have to take out the fuse back to see it though... as for the autos. i haven't a clue...i think its near the front to the right. not sure though
edit: where Spud said it was lol
Old Nov 30, 2006 | 04:00 PM
spudsterier
on the autos is located basically in the same spot......but on the 5-speeds its located on the flat spot of the tranny where the cable bracket is at.....the autos have it mounted on the drivers side ouput shaft
Old Nov 30, 2006 | 04:11 PM
blackattack
i dont understand what they mean by reflow? I have a soldering iron and some soldering wire how do i go about doing it
Old Nov 30, 2006 | 05:22 PM
ZiggyNeon's Avatar
ZiggyNeon
just touch the tip of the soldering iron to the points circled...it will start to burn and change color slightly...when it does its "reflowed"
