will it fit?
Old Jan 30, 2007 | 02:18 PM
das2123's Avatar
das2123
Default RE: will it fit?
ORIGINAL: spudsterier
it is actually even easier to just unbolt the whole setup from the strut and knuckle....leace the knuckle on the car....i only say this because sumtimes its hard to get the bottom control arm bolt off....
Not when you have an impact wrench
Old Jan 30, 2007 | 02:19 PM
spudsterier's Avatar
spudsterier
i used one and still couldnt get mine off[&:]
Old Jan 30, 2007 | 02:40 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
the bolts are splined you have to do it nut side. which das i found out are 18mm
http://home.hiwaay.net/~lbrewer/howto.html
Old Jan 31, 2007 | 12:18 PM
spudsterier
18mm nut.....15mm bolt head
Old Feb 1, 2007 | 04:16 PM
DOHCgarrett t3
is it hard to do a sway bar without a press?
Old Feb 1, 2007 | 05:17 PM
tdizz07's Avatar
tdizz07
if i were to go to a junkyard and get the rear disc breaks would i need to get the ebrake cable as well
Old Feb 1, 2007 | 06:05 PM
das2123's Avatar
das2123
ORIGINAL: DOHCgarrett t3
You don't need a press to install a sway bar.
ORIGINAL: tdizz07
Yes, you need the e-brake cables as well.
Old Feb 1, 2007 | 06:08 PM
DOHCgarrett t3
im not sure but i think the cable is actualy 2 pieces you might have to just get the rear section of the cable
Old Feb 1, 2007 | 06:14 PM
DOHCgarrett t3
i plan to go in uniform to the junk yard so they will do whatever i ask them i want them to flip the car onto its top i wont let them have the fun of removing the parts though
Old Feb 1, 2007 | 06:16 PM
das2123's Avatar
das2123
Nope, it's all one piece per side.
