syntec?
Old Dec 19, 2006 | 03:56 PM
mopar or nocar's Avatar
mopar or nocar
Default RE: syntec?
i know i run rotella in my camaro and my old c20 because it has a higher amount of phosphorus that keep my cams in good shape
Old Dec 19, 2006 | 04:14 PM
das2123's Avatar
das2123
Default RE: syntec?
ORIGINAL: mopar or nocar
Phosphorous is a detergent in oils and is common among all engine oils.
Old Dec 19, 2006 | 09:20 PM
mopar or nocar
Default RE: syntec?
phosphorous also helps prevent premature wear in alot of older engines with non roller lifters have more friction on them and the phosphorous helps prevent the lifter from eating the came lobe. alot of oil companies are cutting back on the amount of phosphorous in the oil wich in tirn is causing camshafts to fail in older engines. ive had 2 camshafts fail because of this in my 81 camaro since ive been running rotella i havent had a problem. chevy had a really bad problem in the 80s with their camshafts failing due to poor metal. if you can get ahold of june 2006 issue of hot rod magazine read the section "when good cams go bad"
Old Dec 20, 2006 | 12:05 PM
das2123's Avatar
das2123
Default RE: syntec?
ORIGINAL: NYG
What About Amsoil and Red Line? True Synthetic?
Yes those are both true synthetics.
Old Dec 20, 2006 | 01:35 PM
hnda8r's Avatar
hnda8r
Default RE: syntec?
So what should you run on high mileage engines. PureSynthetic? or the blend stuff?[>:]
Old Dec 20, 2006 | 02:50 PM
das2123's Avatar
das2123
Default RE: syntec?
ORIGINAL: hnda8r
If you have been using conventional oil then stick with conventional oil. Stay away from synthetic blends.
Old Dec 20, 2006 | 04:03 PM
hnda8r's Avatar
hnda8r
Default RE: syntec?
Well Im using Valvaline Max Life w/ Lucus oil stabalizer. Is this ok?
Old Dec 21, 2006 | 07:13 AM
Ryathis's Avatar
Ryathis
Default RE: syntec?
188,000 in my old dak, all with regular old 10-40, cheapest stuff i could buy, in my opinion its all about maintance, atleast for stock engines. Daytona say 140,000 all with the same oil, trans gave out though damn A-604,S o well though, im not trollin just sold my neon, i miss it, couldnt keep it though, see the sig. for the reason why
Old Dec 21, 2006 | 12:56 PM
das2123's Avatar
das2123
Default RE: syntec?
ORIGINAL: hnda8r
If it works for you, then use it. I don't know about the Lucas stuff...some people like it and some don't.
