cant get the window handle off!
Old Dec 18, 2006 | 08:25 PM
neoncrazy101's Avatar
neoncrazy101
Default cant get the window handle off!
ok well i just got new front speakers..but i cant seem to get the handle for the windows to come off...i also cant get the locking mech. to come off so that i can remove the interior piece. how the heck do u get it off and how do u get the window handle off??
Old Dec 18, 2006 | 08:29 PM
Dazzellerr's Avatar
Dazzellerr
Default RE: cant get the window handle off!
take a fork, yes fork, and bend the two inner prongs down flat, then, place the fork behind the crank handle and there is a little u shaped retainer clip that needs to be pushed out, then the handle will come off. i know, crude but it works. then, once that is off, pull the door panel to unclip it from the door, be careful not to pull it completely away from the door. if you do, you will break your interior door handle. you will see what to do from there.
Old Dec 18, 2006 | 08:34 PM
neoncrazy101
i was thinking there was a clip...but i couldn't find it anywhere!
Old Dec 18, 2006 | 09:00 PM
Dazzellerr's Avatar
Dazzellerr
its real hard to see, but you can if you look and pry real carefully.
Old Dec 18, 2006 | 09:55 PM
das2123's Avatar
das2123
ORIGINAL: Dazzellerr
And be careful because it will fly off. There is a $2 or $3 tool you can get to help remove it.
Old Dec 18, 2006 | 09:59 PM
Dazzellerr's Avatar
Dazzellerr
easy fix to not losing the clip is to hold a magnet by the crank so when it does go, it will go right to the magnet of a speaker, or whatever you use.
Old Dec 19, 2006 | 12:52 AM
FastNeon84's Avatar
FastNeon84
i bought that tool, cost a few bucks...but it works pretty good...just slide it behind the window crank..give it a good push and it will come right off.
Old Dec 19, 2006 | 01:17 AM
Dazzellerr's Avatar
Dazzellerr
yeah, they do make a tool for it, waste of money tho unless you really like to take your door panels apart. i have one at the shop here, but i can never find it. i alwas have my fork in my box tho.
Old Dec 19, 2006 | 01:19 AM
FastNeon84's Avatar
FastNeon84
ahh ok....for your door panels and on your lunch break...lol jus kiddin
Old Dec 19, 2006 | 09:45 AM
spudsterier's Avatar
spudsterier
i still go by the washcloth method...hasnt let me down yet...
i have been hit in the head a few times with those clips...and once in the eye....so be careful
