whats next?
ok. so im stuck. i dont know wat i should put on my car next to get a lil more hp. i al ready have atx tb, msd ignition w/wires, custom exhaust, udp(to be put on) iceman intake, no pwer steering or ac, anda cat delete pipe to put on. whats next. im planing on going turbo sometime soon so i dont want an ecu or anything but something that will help the turbo later.
crane cams. dunno wat you mean by exhaust but if you dun have headers yet I'd get those first. I dunno if a performance pcm would help witout those mods. P&P your intake plenum and your cylinder head,
Edit:if you're gonna go turbo you mite as well get adj. cams you're prolly gonna need em
well i made myself some straight pipes with dual s at the end like an str4 would. i dont want a header because thats wasted money when i put my turbo on. the cams would workthough. as would the p+p
yours i assume from it being an rt is dohc, and the cams in there are not good for a turbo car. you will see no real gain from puting in the crane 16's <which i recommend, right now. but, when you get that turbo on, you will be happy, oh so happy. do not go with the 14's as you will be dissapointed in them and want to goto 16's anyways. do not buy the mmp ecu as you will have to sell it when you go turbo like i had to do.
